Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Severe processing consumption and mild overheating.
This is not the pc I have, however is it he closest one, (mine is a older 2012 desktop of the same design, the original OS was win 8)
I used to get 50 fps on medium graphics with mc, now I get 10 ish, I am wondering if it is even possible to get this thing upgraded since it has dedotated parts, the only none dedotated part is the ram.
It has a AMD A8, 8 gigs of ram, and a almost full ssd, im wondering if putting 16 gigs of ram in will fix the loading times, since thats mainly the issue, and the ram is constantly shown as at 100% alongside the cpu.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Hi @aktinisrelaact
What is the full model number of the AIO as shown on the product information label on the back?
Knowing this will help to find the correct graphics drivers (if they need updating) and also the type of ram, how much ram BIOS supports and in what configuration.
Having near capacity SSD is not good for performance overall as a certain amount of space is required for caching etc. Some recommend minimum of 20% spare others say 10% but most agree not less than 5%
What OS is installed now?
par Partager
Ajouter un commentaire
1 Réponse
Your HP 22-b013w uses an older AMD A8 APU with integrated graphics and mostly soldered parts, so upgrade options are very limited. Adding 16 GB RAM may slightly reduce stuttering and improve loading times, but it won’t fix the low FPS, because Minecraft performance is mainly limited by the weak CPU and integrated GPU. The constant 100% CPU/RAM usage suggests the system is simply being pushed beyond its capability, possibly worsened by background apps or newer Minecraft versions. A nearly full SSD can also slow loading—free up space if possible. Realistically, meaningful performance gains aren’t possible; lowering settings or upgrading to a newer system is the best fix.
Indice 0
Ajouter une réponse
AKTINIS RELAACT sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 132
