Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Documentation de réparation pour la manette Sony PlayStation 5 DualSense de troisième génération. Numéro de modèle : CFI-ZCT1W ID FCC : AK8CFIZCT1A Carte mère : BDM-030
Adaptive Trigger Auto Trigger
I was just finished installing the Hall effect on the controller, and they work fine. However, the trigger motor for adaptive triggers on R2 activates on its own. I disconnected the flex cable, but it still triggers. It doesn't seem to be the springs or anything as the triggers work and they retract, just that the triggers just activate to like a resisting gun trigger every 4-ish seconds. Its seems to be software-related. An y Fixes other than disconnecting the wires?
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires:
Hi!
What does gamepad tester says? Also that it's pressed in? Is the firmware up to date? How are the traces? Are none of them are damaged during soldering?
Thanks!
par
The traces are fine now the auto clicking stopped but when I use the https://ds.daidr.me/ Dualsense Tester the Triggers only go into resistance. The auto trigger mode does the same thing as resistance. The Only trace that was accidently torn isnt even related to that. Im fine without the adaptive triggers but my mute button doesnt work
par
gamepad tester says normal, btw
Its not pressing in on its own, its just the adaptive triggers. Firmware is latest
par
Hmm, can you share some pictures with us regarding the motherboard and it's traces? Then we can take a look at it! Hopefully that is OK :)!
Thanks!
par
Ajouter un commentaire
1 Réponse
Check button for firmware reset.
Indice 0
Ajouter une réponse
Elvin Eve sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 32
Total : 199
