you need to do a bios flush. It is simple, google acer aspire one bios flush and you will get ur answer. Download files on a empty mem stick and folow the procedure. I did mine a couple of times
download new bios from http://sites.google.com/site/maclesblogs...
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn’t boot anymore. It’s only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
2 commentaires
my acer chromebook was working fine last night in the morning i found out it was charging overnight it stopped working it won't turn on please help!!!.
par Suki AH
My Acer laptop suddenly getting off. I don't know why. Again I try to power on but it's not getting on. The indicators also not glowing. Please help me to solve the problem.
par Raagul
