Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en 2018, le ThinkPad X1 Carbon de 6e génération est l'un des ordinateurs portables professionnels les plus populaires de Lenovo. Numéro de modèle : 20QD000BUS
Replacing Keyboard - How necessary is replacing the adhesive and tape?
I am replacing my keyboard and successfully removed the nonfunctioning keyboard, following this guide: Changement clavier Lenovo ThinkPad X1 Carbon 6e génération
During the process, I removed tape (step 25) and broke the adhesive holding the keyboard in place (step 27).
How necessary is it to replace the adhesive and tape? Where would I find the proper adhesive and tape?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @fredlien86
The tape is necessary as it will insulate the metal screwheads in case they touch anything on the motherboard which may cause electrical problems, when downward pressure is applied to the keyboard by the user,
The adhesive will help to keep the keyboard secured to the top cover.
Suggest that you use a suitable width, yellow Kapton tape to cover the screwheads and a suitable width Tesa 61395 adhesive tape for the keyboard.
The manufacturer deemed that it was necessary to use the tape and the adhesive and usually they don't spend more than they have to when making a product.
Image Custom cut rolls of Tesa 61395 double-sided tape for repair.
Produit
Tesa 61395 Tape
$8.95
Indice 2
2 commentaires:
Thanks!
There's still some adhesive residue on the laptop where the keyboard pulled away. Should I try and remove that before applying adhesive tape? Is there a recommended method for doing so?
par
@fredlien86
It is better to completely remove any adhesive residue and then use the Tesa tape to secure the keyboard to the laptop.
Doing this will ensure a more effective and even seal all round and not one that is uneven
Apply a Q-Tip lightly dampened with Isopropyl Alcohol 99%+ (available from electronics parts stores) to the residual adhesive to soften it and then gently scrape it away.
par
Ajouter une réponse
Frederick Lien sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 278
