Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Lenovo ThinkPad Yoga 370 est un appareil 2-en-1 fin, léger et ultraportable doté d'une charnière à 360 degrés, d'un écran tactile multi-touch compatible AES, et d'une option LTE-A pour la connectivité mobile. Numéro de modèle : 20JH002AUS.
Why is my hdmi port not working
Anythinghehehe
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi!
This can be caused by multiple thing!
Do you know if the hdmi port has worked prior? Have you in the past dropped you laptop or spilled any liquid on it?
First of, please verify that the external monitor is working. That it is powering up, and that another device can connect and display to it. Preferably using the same hdmi port in the monitor. If this don't work, please try:
  1. Another cable
  2. Another port in the monitor
If there were any issues with above, please try the new cable / port with your laptop and see if this works. If everything works with the monitor, then it is probably the a laptop problem.
We'll now check some potential hardware issues:
  • Check if the hdmi port looks broken.
    • Do you see any debris? If you see debris, please clean it out with something like a (wooden) toothpick or something similar.
    • Do you see any 'goo' or corrosion?
    • Do you see any bent pins, or any burn marks? Then the physical port is likely busted, and unless you can re-solder a new port on the motherboard (which is an advanced procedure) then replacing the motherboard is the only solutions, which sadly may not be practical.
We will now check some software issues on your laptop, keep your monitor plugged in with these steps:
  • Restart your laptop.
  • Please make sure you have all your drives, firmware, bios and windows up to date. You can find your device drivers on Lenovo's support page. Don't forget to restart your laptop!
  • Please go into your windows settings, enter system settings, and then display (may slightly differ on windows 10).
    • Can you see multiple displays there? If yes, then you should have multiple display options, on:
      • Windows 11, Display settings: at top of the page, in the bottom right of the display layout box, you will see options such as Disconnect this display, next to the Identify button. Press this Disconnect this display, then you should get a drop-down menu, please select Extend desktop to this display.
      • Windows 10, Display settings: Scroll down to the Multiple Displays sections, there you have a box that may say Disconnect this display. Press this Disconnect this display box, then you should get a drop-down menu, please select Extend desktop to this display.
If neither of above solves this, you may want to open up the laptop and inspect the motherboard, especially around the hdmi connector area if you see any disintegrated components, any burns or corrosion. Here is a link to a motherboard disassembly for your model. If you find something problematic, you'd most likely need to replace that component to solve the problem (and that may still not fix it), which would suddenly transform this into an advanced repair. You may also take a picture and upload for us to see if you want, then please see this guide Ajout d'images à une question existante.
If neither of this works, please respond and we will see what we can do!
Good luck,
Cheers
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image Lenovo ThinkPad Yoga 370 Carte mère
Tutoriel
Changement carte mère Lenovo ThinkPad Yoga 370
Difficulté :
Modérée
15 - 20 minutes
Indice 1
Ajouter une réponse
Mohammed Rudha sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 39
Total : 261
