Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why my phone is unlimit rebooted?
Hi, my phone doesn't stop restarting. Interaction with recovery and safe mode did not give anything, as did wipe data, it still does not stop restarting. When you try to flash it to the same system version as it was or newer, an error pops up:
The verification of the brush package failed
Recommended brush package version: (empty)
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
the first thing you should inspect is the Power Button.
Firmware Failed : it typically occurs because the firmware version is incompatible with the phone's Region.
Those are not the cause,the remaining possibility is motherboad error.
Indice 1
2 commentaires:
The power button is not the reason there's nothing wrong with it. In general, it all started with the fact that I was using my phone and it literally turned off in my hands and then went to reboot when I tried to turn it on.
par
You cannot say for certain that a component is 'good' without testing it thoroughly. We need to check everything step by step.First, the easiest test is to leave it on charge until it gains some power. While charging, if the phone turns on by itself without you pressing the power button, then it is definitely a faulty switch issue.Regarding the rebooting, that is typically caused by a failing battery.The final possibility is a motherboard issue.These issues must be diagnosed one by one to find the real answer. You cannot determine what is working or broken just by looking at it.
Good Luck!
par
Ajouter une réponse
Семён Смирнов sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 26
Total : 202
