Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Console portable Nintendo sortie en février 2011, s'identifie au numéro de modèle CTR-001.
Turns on then off, no screen and no popping sound
Hi,
I have a 3DS XL that I cleaned because it was water damaged (nothing burnt on the motherboard so should be fine). It turned on before cleaning, but after reassembly, it turns on and off with the blue led turning on and off too.
I've seen that some people could hear a popping sound, which isn't my case.
I found one of my ribbon cables, with some sort of a black coating around, to have a little scratch and I was wondering if it was the problem.
Can someone help me please ?
Thanks,
Téo
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi!
Unfortunately it could be a lot of things, causing this…
It does look like that the black coating came off a bit, but it’s not sure if this could cause it. Could be any ribbon cable which is not visible damaged.
First,, check if all the corossion is really gone. Also check if all the ribbons are 100% Connected.
If yes, you might want to replace some parts to test… sorry..
Indice 0
5 commentaires:
I've checked again for corrosion, don't see any. The ribons looks perfectly connected (triple checked) and still nothing. I would like to try to replace the ribbon cables, the black coated one first. Do you have any idea what is this ribbon "name" ?
par
that's the camera cable. look in this guide: Changement LCD supérieur Nintendo 3DS XL
par
Yes indeed. I would try to replace that one first as well. Thanks Leo :).
par
Hello,
I've watched a video yesterday from KyleAwsm having a simular issue with a 3DS XL and he managed to fix it. It appears you don't need to connect the camera to boot. So I've tried and nope, still no boot. So my next guess is that the top screen ribbon and/or speakers ribbon are dead. Not sure if I will fix it because I can't find any replacement parts and I had a bad experience with Aliexpress with a 3DS Charger port.
Those cables going through the handle is really a bad idea. If I manage to find new cables, I'll tell you if it is fixed or not.
Thanks for your help !
par
Okay, thanks for letting us know :). Hopefully the new speaker/top screen ribbon will fix it. Please let us know how it goes! Thanks.
par
Ajouter une réponse
tuftouf sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 17
Total : 168
