Aller au contenu principal
Pour réparer ensemble - Je crée un compte
This model Lenovo ThinkPad T490s launched in April 2019 and offers an eighth generation Intel i5 or i7 processor, a 14-inch 1080p display, and a wide variety of ports in a slimmer chassis than the T490 model.
Lenovo T490 ThinkPad Touchscreen Constant Blackout
Why is my screen constantly shutting off and not turning back on by any means besides doing a hard restart?
(holding down power button until cpu shuts off), not control+alt+delete, not escape, not spacebar, not escape, not print-screeen, not windows button, nor any F keys.. Its never a specific key or reason it shuts off and sometimes stays on longer than others. But when it goes off, nothing works whatsoever until i do a shut down, then power on again. I want to smash it, but its new (refurbished bought off of Best Buy)
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
That sounds incredibly frustrating, especially for a "new" refurbished machine. It’s that special kind of tech-rage where you want to treat the laptop like a frisbee, but the "refurbished" sticker reminds you that you still need it to work.
Since a hard restart is the only thing bringing it back to life, the system isn't just "sleeping"—it’s likely hanging or the display driver is losing its mind. Before you take it back to Best Buy, let's run through the most likely culprits for the T490.
1. The "Intel Panel Self-Refresh" Glitch
This is a very common cause for random blackouts on ThinkPads of this era. The Intel graphics driver tries to save power by refreshing the screen less often, and sometimes it just... forgets to turn back on.
  • Open the Intel Graphics Command Center (search for it in the Start menu).
  • Go to System > Power.
  • Find Panel Self Refresh and toggle it to Off for both "On Battery" and "Plugged In."
2. The Critical Thunderbolt Firmware Issue
The T490 belongs to a generation of ThinkPads that had a major bug in the Thunderbolt controller firmware. If left unpatched, it can cause the controller to wear out, leading to display issues, charging problems, and eventually total motherboard failure.
  • Download Lenovo Vantage from the Microsoft Store.
  • Run all System Updates.
  • Specifically, look for Thunderbolt Firmware and BIOS updates. This is non-negotiable for a T490.
3. The "Lid Sensor" Trick
ThinkPads use a magnetic "Hall effect" sensor to tell when the lid is closed. If you have a phone, a smartwatch with a magnetic band, or even a bracelet near the palm rest (usually around the edges or the power button), the laptop might think you’ve closed the lid and shut off the screen.
  • Test: Next time it happens, make sure no magnets are nearby.
4. The External Monitor Test
When the screen goes black, try to plug the laptop into an external monitor or TV via HDMI.
  • If the external monitor works: The problem is likely your LCD panel or the internal display cable (the eDP cable) being loose.
  • If the external monitor is also black: Your graphics driver or the motherboard is crashing entirely.
A Note on Best Buy Refurbished Units
Since you bought this from Best Buy, you likely have a 90-day warranty (or at least a 14-15 day return window).
[!IMPORTANT] If updating the drivers and disabling "Panel Self Refresh" doesn't fix it within 48 hours, return it or exchange it. Refurbished units can sometimes have "ghost" hardware issues—like a hairline crack in the motherboard—that only appear when the machine reaches a certain temperature.
Indice 0
Ajouter une réponse
Matteyag sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 49
Total : 295
