Bambu Lab A1 Mini extruder clicking and filament feed issue
Hello,
I’m trying to troubleshoot a hardware issue on my Bambu Lab A1 Mini Combo 3D printer and would appreciate any guidance.
Hardware reference (for clarity): Bambu Lab A1 Mini Combo 3D printer
Issue description:
During prints, especially at higher speeds or when more filament is needed, the extruder begins to click repeatedly and the filament feed becomes inconsistent. This often results in under-extrusion or gaps in the print. The printer pauses or slows unexpectedly as well.
What I have checked so far:
- Filament spool tension and re-feeding
- Nozzle temperature settings
- Cleaned the nozzle and heat break
- Verified filament is not tangled
At this point I’m trying to determine whether this is likely due to a mechanical feed problem (gears, tensioner, idler), a drive motor issue, or a sensor/stepper calibration issue.
Specifically, I’m interested in:
- Common mechanical causes of clicking extrusion on this or similar models
- How to inspect the extruder gears and tension assembly safely
- Any recommended checks for stepper motor performance or idler alignment
Thanks in advance for any repair/inspection advice — I’m trying to identify whether this is a hardware fault or a setup calibration issue.
