Torn trace in joystick signal path.
Hello everyone,
I’m working on a PS5 DualSense (BDM-030) where I replaced both joysticks with GuliKit TMR modules. During removal of the original left stick, the LSX (left stick X-axis) trace was damaged.
Current symptoms:
Left stick only registers movement to the left, top-left, and bottom-left.
VCC is present (~1.8V).
Ground has continuity.
The LSX signal (middle pin) does not show continuity to any nearby components, so I believe the signal trace is broken.
I previously attempted a jumper to VCC by mistake, removed it, and confirmed the issue is specifically the LSX signal path.
I’m trying to locate the correct series resistor or via for the LSX signal on the BDM-030 board so I can run a proper jumper to the MCU side of the circuit.
Does anyone know:
The exact resistor designation for LSX on BDM-030?
A confirmed via location for that signal line?
A known safe jumper point for this repair?
Any boardview reference or photo guidance would be greatly appreciated.
Thanks in advance.
-Zeek
