Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels et instructions de réparation pour le Macbook Pro 13" avec puce Apple de 2e génération (M2) et écran Retina de 13,3 pouces. Modèle A2338. Première sortie le 15 juillet 2022 à la WWDC 2022 aux côtés du Macbook Air M2.
How can I fix the touch screen right above the keyboards?
My MacBook Pro is a 13-inch Apple M2, 8GB, HC32D6DG67, mac OS Sonoma 14.5. There is a touch screen right above the keyboard and it lights up, but I think it's an external part that needs fixing because the light does not work anymore and everytime I open to start the laptop, it lights up and it lights up non stop but it won't show the keys anymore.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
Were these M2 models 14"?
par
@livfe - This the last 13" model
par
Ajouter un commentaire
1 Réponse
If the TouchBar is lighting up, just not offering the icon's, does the area you would touch still function normally? Often times this also fails. You may want to run diagnostics to see if the failure is seen within it Apple Silicon Mac: Apple Diagnostics for Self Service Repair
Sadly Apple only offers a full uppercase to replace the TouchBar if that has failed, if that's not the issue only leaves us with a logic board problem. One can replace the TouchBar it's self but it's not an easy job as you'll need to take the system almost completely apart to get to it and you do need fully remove it as it's well secured to the case.
Indice 0
Ajouter une réponse
Feleni Petelo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 17
Total : 165
