Orange light rapidly blinking after fully charged
Hello. I decided to change the sticks on my DualSense (motherboard BDM-030) for new ones with Hall effect. After soldering, during the first attempt to power on the gamepad, I received three short orange blinks when connecting the battery or USB cable. After several attempts to power it on, it suddenly started working normally. So I was glad and finished the manual calibration and then the software calibration.
I assembled the gamepad fully and connected it to the tester. During these tests, I found that the speaker is not working (one contact was bent, so I fixed it later) and both types of vibration are not working (wires are soldered correctly). Everything else looks good, except for the battery, which shows a charge of 0-9%. I charged the gamepad for several hours and saw that after a full charge, the orange light blinks rapidly. After connecting it to the tester again, it showed the battery charge jumping from 0-9% to 100% and back.
Visually, I can't find any missing elements. I don't see any shorts for now. During the removal of the old sticks, I damaged a few traces near the stick buttons, but it was just the green mask being removed.
In conclusion, the symptoms are:
- Battery charge jumping from 0-9% to 100% when fully charged.
- Speaker not working (even after fixing the contact).
- Both types of vibration not working.
- The gamepad powers off after a few seconds if connected wirelessly.
Maybe someone has had a similar problem and knows how to fix it? I found one topic with similar symptoms, but there was no solution. I will be grateful for any help.
