Layar bergaris garis putih bagaimana cara menghilangkannya
Habis kena air
Translation Indonesian - English
White lines on the screen, how to get rid of them. After being exposed to water.
Habis kena air
@dindamelia you have to take care of the water damage first.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
It is possible that you have a bad display assembly but for as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
The next thing to do, is to clean it. Since iFixit does not yet have a specific guide for this, use something like this video Remove the main board and the charging board. You will have to remove all the EMI shields off those boards. If you do not remove the shields, you are not cleaning the board. I personally do no longer clean the charging boards, but I replace those. They are fairly inexpensive and readily available at many places. By replacing it I always have a known-well starting point should further troubleshooting become necessary.
Take a close look at all components and connectors to assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean all of your parts (except the display) some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well.
I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. While you clean your boards, check for any obvious damage, like burned or missing components etc. The importance here is the cleaning.
Once all this is done, reassemble your phone and reevaluate. You may still have to replace the display. If so, purchase a display with the midframe already installed. That way you do not have to mess with trying to remove the display form the frame.
Until it is cleaned, everything will only be a guess.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
Untuk saat ini, Anda harus menghentikan upaya untuk mengisi daya, menyinkronkan, atau menggunakan ponsel Anda dengan cara apa pun. Hal ini berpotensi memperburuk situasi yang sudah buruk. Hal ini dapat menyebabkan kerusakan lebih lanjut pada ponsel Anda.
Mungkin saja Anda memiliki masalah pada assembly layar, tetapi selama Anda belum membersihkan papan dan mengganti baterai, semuanya hanyalah tebakan. Perlu diingat bahwa kerusakan akibat air adalah yang paling sulit untuk didiagnosis dan diperbaiki. Tidak masalah apakah ponsel terpapar air selama 2 detik atau 2 jam, yang penting adalah di mana air (partikel) menyebabkan kerusakan.
Langkah selanjutnya adalah membersihkannya. Karena iFixit belum memiliki panduan khusus untuk ini, gunakan video seperti video ini Lepaskan papan utama dan papan pengisian daya. Anda harus melepas semua pelindung EMI dari papan-papan tersebut. Jika Anda tidak melepas pelindung, Anda tidak membersihkan papan tersebut. Secara pribadi, saya tidak lagi membersihkan papan pengisian daya, tetapi menggantinya. Papan tersebut relatif murah dan mudah didapatkan di banyak tempat. Dengan menggantinya, saya selalu memiliki titik awal yang diketahui dengan baik jika troubleshooting lebih lanjut diperlukan.
Periksa dengan cermat semua komponen dan konektor untuk menilai kerusakan. Cari korosi parah, evaluasi pin di konektor, dll. Periksa semua konektor serta ujung kabel. Setelah membersihkan kontaminasi berat, gunakan alkohol isopropil 90%+ dan bersihkan semua bagian (kecuali layar) lebih lanjut. Untuk pembersihan yang tepat, gunakan panduan ini. Panduan ini ditulis untuk Apple iPhone 3G, tetapi semua langkahnya masih relevan untuk ponsel Anda.
Saya tidak bisa cukup menekankan pentingnya pembersihan yang baik, jadi lakukan berulang kali sambil mengganti alkohol setelah setiap pembersihan. Hal terbaik yang dapat dilakukan adalah membersihkannya dengan pembersih ultrasonik, tetapi jika Anda tidak memiliki akses ke alat tersebut, ini setidaknya akan membantu. Saat membersihkan papan sirkuit, periksa adanya kerusakan yang jelas, seperti komponen yang terbakar atau hilang, dll. Yang terpenting di sini adalah pembersihan.
Setelah semua ini selesai, rakit kembali ponsel Anda dan evaluasi kembali. Anda mungkin masih perlu mengganti layar. Jika demikian, beli layar yang sudah dilengkapi dengan midframe yang terpasang. Dengan begitu, Anda tidak perlu repot-repot mencoba melepas layar dari bingkai.
Sampai dibersihkan, semuanya hanya akan menjadi tebakan.
Saat Anda bekerja pada ponsel Anda, ambil banyak foto. Setelah selesai, gunakan foto-foto tersebut untuk membuat panduan di iFixit. Hal ini akan membantu orang lain yang memiliki perangkat dengan masalah serupa. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai kontribusi Anda.
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 32
