Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Console portable Nintendo sortie en février 2011, s'identifie au numéro de modèle CTR-001.
3DS Charges But Does Not Turn On (No Blue Light)
I have this original 3DS that had some corrosion in it near the power management section.
I cleaned it up using a toothbrush and 99% IPA.
Even after the clean, it produced the same results of claiming to be charging but never actually turning on or showing the blue LED.
I checked for shorts, couldn't find any. I also check F1 and F2 fuses which both showed to be fine.
I know there was a lot of corrosion but I just don't know what the problem could be. If you have any advice, please let me know
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires
@johndoe11771 check the inductor marked 2R2 in your 3rd and 4th image. It does look cracked.
par
@oldturkey03 The 2R2 does work fine. I haven't tested with the battery in but it passes the continuity check just fine. Chances are its the PMIC
par
@johndoe11771 lots of flux and reflow that board on the area that had all of the corrosion.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi!
That is a lot of corrosion. For sure something is damaged on the motherboard.
Most likely you need to replace the IC’s there and maybe some caps as well.
I think you are better off with a new motherboard if all the power rails and fuses are fine… sorry
Indice 1
2 commentaires:
Yeah, honestly I think this is a lost cause but im still pushing for any possible fix. At this moment, it seems like it is the PMIC. I want to try soaking it in IPA, then a reflow to see if that fixes it because I can't find a single short anywhere.
Thanks for the help
par
Hi!
Yes, I think that one is damaged indeed.
Not easy to replace it, but worth a try.
Please try the cleaning first, otherwise replacing is probably required..
par
Ajouter une réponse
John Doe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 36
Total : 223
