My phone got bootloop and then bricked
my phone got bootloop and then when i was at the recovery mode it got bricked now it won't turn on
I've had a Pixel that looked like it was bricked; wouldn't turn on, no charging indication, nothing. It recovered completely when I unplugged the battery for about a half hour then plugged it back in. No idea if a half hour is necessary; that's just what worked for me, but you could try that and see if anything changes.
Do you get any indication of life whatsoever, a charging indication when you plug it in, or being recognized when you connect to a computer?
i have bricked pixel 6 same condition as you. i left the phone unused for months only to return to this paper weight. i saw VID_18D1&PID_4F00 in Windows Event Viewer when i connected the phone to my pc after charging it for an hour. in the forums i saw that it means it went into emergency recovery mode based on exynos firmware. there are no available fix for this except a repair work (ufs reflash or board replacement) or to wait for google release official image file or tools. or else wait for some exploit BROM. i wanna know what is it with you phone, why it got bricked and how exactly you got it to boot, what it booted into (recovery, fastboot, or pixel os bootloader). thank you!
@arulprakasha I have no idea what was going on with the phone; it appeared to be completely dead, no charging, no connection to computer, nothing. I opened it up to see if I could visually locate a problem, but found nothing at all. After a half hour of examining it, I reassembled it enough to power it up, plugged the battery back in, and it came to life like nothing was ever wrong with it.
So I'm sorry, I don't have any more help for you; there were no error messages to be seen, and it worked normally after that and still is to this day.
oh, thanks! ill surely try that out!
Use the hotkey of Up/Down Volume key and power button whilst it is plugged in. If you can boot into the Recovery Environment, use the official flash tool: https://flash.android.com/ and see if you can fix it that way.
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 51
Total : 193
Believe I have the same issue. Volume buittons weren't working, and when I rebooted the phone it went into fastboot. I think one of the volume buttons is stuck in the active position.
par Andrew W
