Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en 2010, identifiable par le numéro de modèle WT092EA.
My lap top is blurry screen and does not communicate
Blurry screen of my laptop and doesn't communicate
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
@phrass does no communicate how? Communicate with what? Give us more information on that.
Connect an external monitor and see if that displays clearly. If so, you know the issue is your LCD and might need replacement.
par
Ajouter un commentaire
1 Réponse
A blurry screen plus no response usually points to display or system issues. First, restart and check resolution (set to recommended) and scaling in display settings. Update or reinstall graphics drivers. Try connecting to an external monitor—if it looks fine, your laptop screen or cable may be faulty. If it’s blurry even in BIOS, it’s likely hardware damage. Also check for loose display connections if you’re comfortable opening it. For “not communicating,” test keyboard/trackpad and USB ports—could be driver or motherboard issues. Run system diagnostics or reset the OS. If problems persist, get it checked by a technician.
Indice 0
Ajouter une réponse
PH RASS sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 79
