Mi-2006 / numéro de modèle A1181 / coque noire ou blanche / processeur Intel Core Duo de 1.83 ou 2.0 GHz.
Questions au sujet de 516 Voir tout
Suspending immediately after boot.
I've just replaced the upper case cable, following the guide on the site.
The replacement went fine and now the computer recognises the power button the keyboard and the trackpad.
Unfortunately it seems that i've done something wrong since the laptop suspends immediately after boot.
I can always wake it up after the suspend but it will re-suspend after few secs.
When i wake-up the computer I can see that the login screen is properly loaded but I don't enough time to try to login.
It seems like the laptop believes that it has to stay always in suspend mode. Anyone has an idea of which could be the cause?
Une réponse ! View the answer J'ai le même problème
Commentaires:
When you say suspend do you mean that it freezes?
par
I'm mostly a Linux user, I would call it suspend to ram, but mainly I'm referring to what happen when you close the lid.
par
Hi All I'm still struggling with this problem, anyone has ever seen anything similar?
Thanks a lot.
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Try starting up in Safe mode by holding down the Shift key on startup. Then check your Energy Saver preferences.
Cette réponse est utile ?
Score 3
Commentaires:
Thanks for the suggestion, I've tried it, but it seems that there is not enough time to trigger the safe mode, the laptop goes in suspend/freeze immediately after boot and I cannot prevent this.
Could it be a sensor that claims that the lid is closed and hence force the suspend?
Or could it be a overheating problem (even though i can hear the fan starting)?
Thanks again
par
Why did you replace the upper case? Did you spill something on it that may have gotten through to the logic board?
par
Hello there again.
I had to change the fan cause it was doing noise, and while doing this by mistake i broke the connector of the upper case cable.
As far as i can tell nothing went on the logic board.
Thanks again.
par
Take this in to an old computer guy that can solder the connector back on.
par
I already have bought the new upper case cable, and replaced it.
It seems to work, since i can see the led of the caps-lock working and i can power-up the laptop.
The problem is that the laptop goes immediately sleep mode every time.
par
Ajoutez une réponse
Antonio Rago sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 466
