Stuck On Home Menu: Inputs, Sound, 3D Slider Don't Work
I received a 3ds in a lot of damaged electronics. I've managed to repair everything so far except this 3ds which has me stumped.
The system turns on and loads to the main home screen. The top screen animation runs, I can turn the wifi on and off, the game reader reads games, the system charges, if I hold the power button to get to the power down screen, I can press the home button to get back to the home menu, and I can enter the update/safemode screen when holding L+R+A+d-pad up (Edit: was d-pad down, I meant d-pad up). I cannot enter into touch screen calibration, touch input doesn't work. On very rare occasions if I'm holding down d-pad right when powering on the system, the home menu will start scrolling right indefinitely and I'm able to "fight" against it by repeatedly pressing d-pad left and only when in this state I can enter into an app if press A at the right moment (which is how I know the cameras work), but the touch screen still wont work.⏎
Otherwise though, the joystick, touch screen, ABXY, sound, and 3d slider do not work at all.⏎
I've already tried cleaning under and changing out the digitizer, as well as the bezel, and cleaning under the button pad stickers. I've also tried systematically disconnecting one component at a time and testing to see if anything changes or works. Unfortunately, though, none of this has seemed to work. ⏎
The scrolling right only happens when I have the system taken apart, but it isn't consistent with any specific component being disconnected.⏎
The battery does have a slight curvature to it, but I'm not sure if that would cause these issues. ⏎
Any suggestions would be greatly appreciated!!⏎
Thanks!
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
Is the 3DS modded? It sounds like the sort of thing failed modding could do. And definitely replace the battery. It's probably not the problem, but if it's curved, you're probably going to have to replace it at some point, and you may as well do it while you're taking it apart already.
par
@fixerofstuff I thought it could've been a bad mod as well, but I can't see any other indicators of modding (no menus on start-up when holding select at least). Didn't come with any SD cards for me to check out either.
par
Hi!
Hopefully @darthmango can check this. Do you have any ideas?
Thanks!
par
Ajouter un commentaire
