Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti le 13 octobre 2016, le PlayStation VR est le premier casque de réalité virtuelle de Sony conçu pour fonctionner avec la console de jeux PlayStation 4.
Why is the PSVR (V2) not outputting to the left earbud?
Regardless of what kind of wired headphones I use, the left speaker does not work with any reliability. The included earbuds work fine with other devices, but not the PSVR (V2) headset. I can occasionally get it working, but I can’t get it to work consistently.
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
Hi!
Can you let us know which earpods you used? And also, do you connect them straight to AUX, or is there any adapter connected?
Thanks!
par
I use the earbuds that came with the VR headset and attach to the back, connected into the AUX with no adapter. I got the same results plugging in different headphones the same way. I also tried plugging the earbuds into a different device and they worked fine, so it has to be something wrong with the VR headset itself.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Peter!
Thanks for your response!
You did try everything to test, so it’s most likely related to the AUX port.
Did you tried to clean the AUX port? Would do that first.
Worst case, you need to replace it. The only issue here is that it’s very difficult to find the replacement part and repairing it, will not be easy as well…
If you want to replace it, I recommend to find a broken one and get the AUX port from that one.
The closest guide that will get you there is this one: Changement carte de suivi LED arrière PlayStation VR
Hopefully that will help you to get it fixed!
Please let us know how it goes!
Indice 1
Ajouter une réponse
Peter S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 27
Total : 189
