Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercialisé le 24 septembre 2021, l'iPhone 13 mini est une version petit format de l'iPhone 13 et le deuxième iPhone mini. Il est muni d'un écran OLED 5,4 pouces, d'une puce A15 Bionic et d'une caméra arrière double.
How to disable proximity sensor check? Phone restarts every 5mins
Hello,
is it somehow possible to disable the "proximity sensor" check? The proximity sensor cable was damaged, so I unplugged it.
The phone is now automatically restarting every about 5mins.
I honestly don't need the function of the proximity sensor but I don't want that the phone keeps restarting.
Is there an other fix than replacing the sensor?
Thanks!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
To the best of anyone's knowledge outside of Apple, there is no way to disable the three minute sensor scan. As such, if you want your phone to be usable, you will have to replace the damaged component or repair the flex cable.
You say you don't need the proximity sensor, but it affects how you make and receive phone calls. Its major function is to turn off the screen and disable the touch screen when you hold the phone up against your face; without the proximity sensor, you'll be making random touches on the screen with your face, resulting in who knows what function. So unless you plan on making all your phone calls on speaker, it's advisable to replace the sensor.
Naturally Apple is making this process as difficult as possible. Aftermarket repair parts are readily available both here at iFixit and elsewhere, but you will lose Face ID if you use them. If you are updated to iOS 18 or later, you can use the Repair Assistant to pair a new or used genuine Apple front sensor assembly to your phone and get back the Face ID functions. Note that if it's a used part, the phone it came from cannot have been reported lost or stolen.
So your choices are to use an inexpensive aftermarket part and live without Face ID, or buy a new or used genuine Apple part and get your phone fully functional again. Either way the three minute boot loop will stop and you'll be able to use your phone again.
Indice 2
Ajouter une réponse
hannes556 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 103
Total : 523
