Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tout sur la réparation iPhone 14 Plus. Ce nouveau format Apple pour la gamme 14 comprend un écran OLED de 6,7 pouces – comme le Pro Max – mais les mêmes caractéristiques que l'iPhone 14 avec une configuration à double caméra et la puce Bionic A15 au processeur graphique à 5 cœurs.
Can anyone tell me what the issue can be, any guess
I have an iPhone 14 Plus that was water damaged. I cleaned the motherboard properly using isopropyl alcohol and then lightly dried it with a heat gun just enough to evaporate the alcohol. After that, I reassembled the phone. I cleaned all components the same way except for the charging port assembly. I only cleaned the charging port from the outside and did not remove or clean the flex cable.
I also replaced the battery with another one to rule out any battery-related issue.
After putting everything back together, the issue still persists. When the phone is unplugged and I try to turn it on, it makes a small “cling” sound and then goes directly into DFU mode. It keeps repeating this behavior every time I try to power it on.
When I connect the phone to a laptop while it’s in DFU mode and attempt to restore it using iTunes, the restore process starts but freezes halfway through. The screen stays stuck for a long time and does not complete. I repeated the process multiple times with the same result. I also tried restoring using 3uTools, but it behaves the same way, the restore begins and then gets stuck halfway.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hello Umer
Well we’ll need more info there regarding the % where it stops on 3utools and a picture of the 3utools restore log would be great as well
I’d assume its a board issue 80% some line is shorted/partially shorted somewhere
Indice 0
Ajouter une réponse
Umer Abubakar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 21
Total : 79
