Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'installation électrique aux États-Unis désigne le processus d'installation de systèmes électriques dans les bâtiments et les structures, conformément aux réglementations établies par le National Electrical Code (NEC) et les codes du bâtiment locaux.
Why is the kitchen sink drain overflowing?
The kitchen sink does not drain used water out, instead it remains full in the since.
The vacuum switch to help suck out the water is not working.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
If your sink is below the sewer line elevation you need a holding tank which then is evacuated by a pump that emulates the needed lower elevation of the waste line.
Do you hear the pump motor running? If not the pump may have failed and/or it's not getting power. If you do hear the pump, but the water is still sitting in the basin the plumbing maybe clogged and/or the one-way valve to prevent back flow where dirty water can enter back into your sinks basin which you don't want.
You do need to be very careful as sewer water can carry some nasty bugs! Make sure you wash down the area with bleach as well as anything that could have been splashed and your sponges and cloths!
Indice 0
Ajouter une réponse
DOROTHY GENDI sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 20
Total : 126
