Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ordinateur portable 15,6" pour les entreprises et les PME Type d'ordinateur portable : taille moyenne, économique, écran HD Fabricant : HP Processeur : AMD Athlon II P340 / 2,2 GHz Nombre de cœurs : double cœur Cache : L2 - 1 Mo Informatique 64 bits : oui Type de chipset : AMD M880G
Battery charge system is disturb much after remove gharge
is turning off when charge removed even when battery is full
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
answer
please
par
Ajouter un commentaire
1 Réponse
As batteries age, they lose the ability to hold a charge. Think of your battery like an empty jar that you fill with water (charge the battery). Each time you charge it, you add a marble; that represents the degradation of the chemical reactions that take place each time it's charged and discharged. One marble doesn't make much difference, but over time eventually the jar is full of marbles. Now when you fill it with water, the amount it can hold is only a fraction of what it could originally take. So even though it's 100% charged, there really isn't much charge inside, and when it gets bad enough, you end up in the situation you find yourself where after being fully charged, it can't even power the laptop and shuts off immediately when the charger is removed.
First thing you'll want to do is check the battery health; that will tell you what the current capacity is versus what it should be able to hold. This page will show you how to check it both with a Windows command and with the HP Support Assistant.
How to Check Battery Health of Your Laptop
Once you know the battery health percentage, that will help judge whether it needs to be replaced (I'm guessing it does, based on your description). On an iPhone, Apple recommends replacing the battery when it gets below 85%, but the rule of thumb for laptops is anywhere in the 70-80% range. Generally you'll start seeing problems when the percentage gets down to 60-70% or lower, at which point it's time to replace it.
HP batteries are made to be easily user replaceable, and if you need instructions you can find them in the HP Maintenance and Service Guide.
HP ProBook 4525s Notebook PC - Maintenance and Service Guide
The battery replacement procedure can be found on Page 48 (go to page 56 in your PDF reader). It's fairly short, so I copied it here for your convenience.
Good luck, and be sure to come back and let us know what you find!
Indice 0
Ajouter une réponse
ELLY ELLY sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 90
