Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de la Xbox Series S, la nouvelle console de jeu numérique de Microsoft. La Xbox Series S est sortie en même temps que sa grande sœur plus puissante, la Xbox Series X, le 10 novembre 2020.
Does not power on, have shorted capacitors
During some testing I found sticky residue on one of these chips “marked in red” and all of the capacitors in the “highlighted yellow” area are all shorted. The Xbox does not turn one and would like some input if possible thank you.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @tylerferguson
It’s very unlikely that all those SMD capacitors are actually shorted. What you’re seeing is the effect of measuring across a rail that’s being pulled down somewhere else — since the capacitors are all probably in parallel, they’ll all read short even though they’re fine.
The sticky residue you noticed is most likely flux. A bad IC on that rail can cause the short reading across the capacitors. In cases like this, it sometimes helps to remove the suspect IC and measure the rail again. If the short clears after removal, you’ve found your culprit. If it doesn’t, then the fault lies elsewhere in the power delivery path (often a MOSFET or regulator).
So in short:
  • Don’t assume all the capacitors are bad.
  • Clean the area to rule out conductive residue.
  • Focus on the ICs and MOSFETs tied to that rail.
  • Removing the suspect IC and re‑testing is a solid way to confirm whether it’s the source of the short.
Indice 1
1 commentaire:
So did some testing and found that my 3.3v is shorted, I’ve tried to inject some power and can’t find anything heating up, I tried using ipa I don’t have a thermal camera.
par
Ajouter une réponse
Tyler Ferguson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 27
Total : 96
