Still not powering on after battery replacement
I replaced the battery on my surface pro 7 and before the swap, The charger would double blink indefinitely until it was disconnected, After the battery replacement it blinks 1 - 2 - 2/3 -2 and then stops until I press the power button again, Both before and after the replacement there is a red light that stays on solid on the motherboard next to the SSD, The red light only goes out when I disconnect the battery or have the surface connected to the adapter only, I tried button combos to no avail, The display just stays off and the fan doesn't move either. I also tried multiple different adapters and USB-C charging at 65w.
