Accessory drive won't turn unless pushed in.
My Kitchen Aid Pro 600 recently stopped turning the planetary shaft. I disassembled it and found that the play in the shaft was allowing the bevel gear to slide above the pin that engages the shaft. I replaced the composite washer at the bottom of the planetary shaft with at thicker one, and that eliminated the vertical play in the shaft so the bevel gear again engages the pin; however, now the accessory drive shaft will only turn if held in from the outside, as though it were missing a thrust washer, but there was no washer when I first disassembled it months ago for a different repair, and none of the videos I've watched show one, either. Seem unlikely that the gears would be that worn, but I'm no expert. Any ideas?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
