Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et le démontage du ROG Ally, une console de jeux portable fabriquée par ASUS. Sortie en 2023 et identifiée par le numéro de modèle RC71L.
The power adapter cable isnt working properly
My charger is at the point where it will only work if you bend it. Usually, I would just replace the cable. But with this type of charger, it's obviously more complicated to do. Please advise on how to replace the cable.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Because the Asus ROG Ally charger is a sealed, proprietary USB-C unit, repairing the cable requires advanced soldering skills. Instead of trying to fix the worn cable, it is strongly recommended to purchase a new 65W (or higher) USB-C PD charger or a high-quality 100W USB-C cable, which will restore full 30W Turbo mode functionality.
Recommended Solutions:Best Solution: Buy a reliable third-party 65W+ USB-C charger (like Anker or UGREEN) to avoid the proprietary cable failure point.Preventative Measure: Buy a 90-degree right-angled USB-C cable to reduce stress on the port and cable, which prevents future bending issues.
f you must repair the current cable:Cut & Splice: You will need to cut the cable below the damaged area, strip the wires, and splice/solder a new USB-C connector (or a donor cable) to it.Multimeter Required: You must use a multimeter to map the wires correctly (positive, ground, and data lines) to avoid damaging the ROG Ally.Insulation: Ensure each wire is insulated with heat-shrink tubing to prevent short circuits.
Indice 0
2 commentaires:
I bought a third party 65w usb c adapter, it charged normally but turbo mode went from 30w to 25w. Is that normal, does it only recognise its own propietary chargers to activate that 30w turbo mode, or is there a setting or two i can change to make it work properly
par
It’s normal might just be that you bought a different cord
par
Ajouter une réponse
Obiwan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 30
Total : 145
