Aller au contenu principal
Pour réparer ensemble - Je crée un compte
My laptop is not turning on
Pc is not turning on even whoen it is charged
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@vandith you are not giving us enough information. We need to know the exact model for your computer and we need to know if it gives you any sign of life. Also, let us know what you have already checked and what you have already tried.
For now, start with the basic generic troubleshooting. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Ajout d'images à une question existante
Indice 0
Ajouter une réponse
vandith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 68
