Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La mise à jour de mars 2015 du MacBook Air 13" d'Apple intègre des processeurs Intel Core i5 et i7 de cinquième génération, offrant une légère augmentation des performances et de l'autonomie de la batterie.
Wont turn on after randomly turning off
Ive bought a macbook air A1466, used to have a macos device for messing with my older iphones.
Ive been using it for a month and a half and when i turned it on last morning it booted up, i entered my user password and went away. when i came back it was on the desktop and it randomly went blackscreen.
I thought it just fell asleep but pressing keys and touchpad nothing happened -it wont turn on anymore, no chime, no fan, nothing. I tried pram reset(but no apple logo when booting so didnt really work..), smc reset multiple times.
Unplugged battery, also took it mostly apart, put everything back, checked connectors.
Only issue is that the bluetooth-airport card's one of the connector wont go on, but that has been like that since i bought it and it worked. Also the screen has dark spots and light spots -probably liquid damage(some extra info). But liquid indicators arent red on the board or anywhere... but theyre yellow-ish..??
Also battery health was like 39% (in coconut battery), but as i said it worked completely fine before, and unplugging the battery from the board still didnt work. Magsafe charger is orange, but after a bit turns green.
What can i do to make the machine work again?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
What is the color of the MagSafe cords LED?
par
@danj orange, and then after a bit its green
par
Ajouter un commentaire
3 Réponses
Solution retenue
Well it works now thanfully! i went to check in the morning.... bam opened it up and it booted right up. no idea how but im happy it works!
Indice 0
Réponse la plus utile
Obviously the battery is on it's last legs and failing as it is at just 39% capacity, this can and likely has caused an issue on the board as the battery can be malfunctioning. Have you tried connecting the charger with no battery installed or connected?, the unit should auto boot, if so then the battery is the issue at hand., if not then you'll need to check the main power rails for a shorted circuit.
Indice 1
3 commentaires:
i tried unplugging the battery, holding down the button and then connecting it, nothing…. even pressed the powerbutton, which are the powerrails?
par
@hecker3316 Did you notice if the fan started to spin and then cut off? If so, this may indicate an SMC issue.
par
@livfe nope, fan didnt spin up
par
A sudden shutdown with no chime, no fan, no display, and no response to SMC/PRAM resets usually points to a hardware fault rather than software. Since the MagSafe changes from orange to green, the charger and charging circuit may be partially working. Given the existing display damage, possible liquid exposure, poor battery health (39%), and a loose AirPort/Bluetooth connector, the most likely causes are a failed battery, DC-in board issue, power rail failure, or logic board damage. Try disconnecting the battery and powering only from MagSafe, inspect for corrosion under magnification, and reseat all connectors again. If still completely dead, the logic board likely needs professional diagnosis or replacement.
Indice 0
1 commentaire:
it still wont boot with an unconnected battery(magsafe charger plugged in). may sadly be a board issue
par
Ajouter une réponse
hecker sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 175
