Não funciona a câmera frontal
Parou do nada de funcionar a câmera frontal
Translation Portuguese - English
The front camera isn't working
The front camera suddenly stopped working
@sarahelenam7635 it is possible that this is due to a corrupted camera app cache or a hardware failure like a bad camera or the connection to the main board. Start by clearing the Camera App Data:
Go to Settings ==> Apps & notifications ==> App info ==> Camera ==> Storage. Tap Clear Cache, then Clear Data. This should cause the camera app to reinitialize the hardware connection.
Next, try the camera with your phone in safe mode. Press and hold the Power button, then tap and hold the "Power off" on-screen option until the Safe Mode prompt appears. If the front camera works in Safe mode then one of the third party apps installed on your phone is blocking access to your camera. You will need to start removing those Apps until you find the one that is the cause for this.
If it also does not work in safe mode you could download a diagnostic App to "ping" the camera directly. If the system can't see the camera hardware at all, you are looking at a complete disconnect. Could be that the camera module is disconnected or it failed completely.
Now it's time to open the phone to check/replace your camera. Since iFixit doesn't yet have a specific guide for that, use the one from here It is written in Spanish. Use a browser that will do the translating for you, if needed. Check the camera connector to make sure it is fully seated etc. If so, then replace the module to repair your K40.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their phone. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@sarahelenam7635 é possível que isto se deva a um cache corrompido da aplicação da câmara ou a uma falha de hardware, como uma câmara avariada ou um problema na ligação à placa-mãe. Começa por limpar os dados da aplicação da câmara:
Vai a Definições ==> Aplicações e notificações ==> Informações da aplicação ==> Câmara ==> Armazenamento. Toca em «Limpar cache» e, em seguida, em «Limpar dados». Isto deve fazer com que a aplicação da câmara reinicialize a ligação ao hardware.
A seguir, experimenta usar a câmara com o telemóvel no modo de segurança. Mantém premido o botão de alimentação e, depois, mantém premida a opção «Desligar» no ecrã até aparecer a mensagem do modo de segurança. Se a câmara frontal funcionar no modo de segurança, então um dos aplicativos de terceiros instalados no teu telemóvel está a bloquear o acesso à câmara. Vais ter de começar a remover esses aplicativos até encontrares aquele que está a causar o problema.
Se também não funcionar no modo de segurança, podes descarregar uma aplicação de diagnóstico para «pingar» a câmara diretamente. Se o sistema não conseguir detetar o hardware da câmara de todo, estás perante uma desconexão total. Pode ser que o módulo da câmara esteja desligado ou que tenha avariado.
Agora é hora de abrir o telemóvel para verificar/substituir a tua câmara. Como a iFixit ainda não tem um guia específico para isso, usa este aqui. Está escrito em espanhol. Se for preciso, usa um navegador que faça a tradução por ti. Verifica o conector da câmara para teres a certeza de que está bem encaixado, etc. Se estiver, substitui o módulo para reparares o teu K40.
Enquanto trabalhas no teu telemóvel, tira muitas fotos. Quando terminares, usa essas fotos para criar um guia para o iFixit. Isso vai ajudar a próxima pessoa que tiver os mesmos problemas com o telemóvel. É fácil e divertido criar estes guias. https://ifixit.com/Guide/new A comunidade do iFixit vai ficar grata por isso.
A reparação é uma guerra contra a entropia!
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 28
Total : 71
