Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tablette haute performance d'Apple.
How to loosen a stuck power button that is jammed
How can I loosen it without taking the screen off
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
It depends on what caused it to be stuck! Using distilled water wetting a Cotton Swab wiping the area and exercising the button is the first way if you got something sugary into it. If you just got hand cream or sunscreen give 90% isopropyl alcohol a try again wiping the button down.
The last try is using some WD40 A light machine oil which can seep in a bit. Again, using a Cotton swab that's not to wet as it would need much and you may need a few treatments. That should help if something oily or waxy is it will rehydrate the material allowing the button to be free. Do take the time once the button is released to wipe the sides down getting anything left off.
if the spring has shifted or just failed you'll need to then open up the iPad. What is your exact modem so we can aim you to the correct guide and needed tools.
Indice 0
Ajouter une réponse
Ronald James sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 29
Total : 76
