Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et informations sur les cafetières Hamilton Beach.
Coffee maker is slowly leaking clear water from the bottom.
I believe my Hamilton Beach 12 cup coffee maker 49465R needs a new hose, but where do I get one? The company doesn't sell them, eBay doesn't have any, ifixit doesn't have any. Looking for advice on how to DIY a hose. Is the tubing similar from one coffee maker to another...in other words, could I buy a tube from say DeLonghi and cut it to fit?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
@lee94517 let's see what our coffee maker Guru @vauweh says about that :-)
par
The hose in question is seen on the right. Both clamps on that hose are also quite rusted. Sorry the image quality isn't better.
[image|4606420]
par
Ajouter un commentaire
3 Réponses
Solution retenue
We don't know what kind of hose this is—can you show us a photo? Usually, only the inner diameter matters, and it needs to be resistant to hot water; silicone is the most common material. The brand doesn't matter.
Indice 2
2 commentaires:
Hi, I'm sorry I only just now discovered that you had answered. I can't seem to attach an image to this reply. I think I have to "answer" my own question in order to do that....
par
A coffee maker leaking clear water from the bottom is usually caused by a cracked water reservoir, loose internal hose, worn seal, or faulty valve. Inspect for visible cracks and check the internal tubing and gaskets for leaks.
Indice 0
1 commentaire:
Thank you. I've checked those components and one of the hoses appears to be the culprit.
par
Indice 0
Ajouter une réponse
Lee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 21
Total : 61
