Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La onzième génération de la Toyota Corolla a été commercialisée en mai 2012. Au Japon, la berline est appelée Corolla Axio, tandis que la variante break est nommée Corolla Fielder.
On the dashboard meter screen when the car is engaged into drive the (
On the dashboard meter screen when the car is engaged into drive the (D) light after sometime starts blinking at that moment the gear selection starts to malfunction
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
The brain box has fault
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
A blinking D light is your transmission's version of a Check Engine light. It indicates that the Transmission Control Module (TCM) has detected a fault in the transmission's operation and is trying to tell you something's wrong.
You will have to get the car scanned through the OBD-II port, but be aware that standard scanners can only access the engine computer; it requires a specialized scanner to read the transmission codes. A dealer or a transmission shop will be able to pull the codes, but it's possible a regular mechanic may have the right equipment.
Whatever you do, do NOT ignore it; it could be warning you of a catastrophic problem that can end up costing you thousands if you don't address it.
Indice 2
Ajouter une réponse
yahaya sherifdeen Omeiza sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 59
