Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why is the pc battery power draining even when it's plugged? in
When I plug my PC into a power supply, it indicates that it's charging, but the battery power continues to drain.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Power supply cannot keep up with the power drain.
You'll need to use the correct power supply via USB C that can supply the maximum 65W. If the device is under heavy load, it will overdraw and consume power from both the battery and AC supply. - This depends entirely on your specific devices configuration.
You could try adjusting your power saving settings (or turning them on)
Indice 0
Ajouter une réponse
ssemugabi joshua sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 81
