Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La mise à jour de mars 2015 du MacBook Air 11" d'Apple est dotée de processeurs Intel Core i5 et i7 de cinquième génération, offrant ainsi une légère amélioration des performances et de l'autonomie de la batterie.
No Internal or External Display Issue
Have a 2015 A1465 here (820-00164) that chimes / boots but there is no display at all. We have tested with another known display assembly & on external displays but still nothing. From what we can see we are getting readings from the outputs, but nothing, just a black un lit screen. GPU failure I thought gets a white screen. The fan is also at high speed. What can be? (I do believe that the technician has replaced the SMC 2x already).
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
Does the system respond when you use the system in Clam Shell mode you do need external keyboard and mouse here besides the external display connection. The lid must be down as the Hall sensor needs to see the lid is closed to enable the external as the primary display.
par
@danj Will try it. And update as and when.
par
Unite is dead, green light only, no fan spin, zero..... donor unit.
par
Ajouter un commentaire
2 Réponses
Try connecting it to an external monitor but with the lvds cable disconnected
Indice 0
1 commentaire:
@nik_one - Disconnecting the LVDS cable won't change anything here from a diagnostic sense. If the LVDS connection was corroded up then I could see that resolving a possible short.
Putting the system into Clam Shell Mode would be easier and offer a useful data point.
par
If you can get the external display to respond then you should be Ave to identify the system issue going into CPU Safe Mode. If you can't get into Clam Shell mode that points to a CPU module issue where the I/O chip part has failed.
Indice 0
Ajouter une réponse
livfe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 95
