Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Kia Soul est une voiture compacte conçue au centre de design de Kia en Californie, présentée au Mondial de l'automobile de Paris 2008, fabriquée en Corée du Sud et commercialisée depuis 2009.
Why when I put gas in my car it’s hard to stay started unless I rev it
When I put gas in my car it’s hard to stay started unless I rev it for some seconds and then it’s fine. This only happens when I go to put gas in it
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
This is usually low fuel pressure, a weak starter or a bad battery a lot of the time, but it might be your EVAP purge valve if it occurs after a refueling. If you have the code P0441, it's usually the purge valve.
First thing you want to do if the valve is fine or you replace it is check the battery health, especially if you have a tester at home or know someone with one - worst case, if you are in the US the parts stores will test for free. I have run into this on a 2015 Optima where the start was rough (as in 3 degrading initial turns, it took 5 cycles to start). I have a battery tester at home so I ran that and found the battery is bad. Swapped it and it helped a lot, the starts are strong for a Hyundai now at least, but I still suspect the starter is aging out at 102k miles as it's not perfect and sounded a little weak. I might be looking at a starter replacement if it does it again.
Next thing is to investigate the starter. If it's accessible, hit it with a rubber mallet - if it comes back, the starter is going bad. You can only hit it a few times, so treat it as an emergency fix to get it A to B to a mechanic, or time to order one. It's also riskier on newer starters, so this is an emergency fix to get it to the shop only.
If both the starter and battery aren't it, the fuel pressure is weak. Get a scanner like the Innova 5610 and test the fuel sending unit. You will also want to check the fuel rail and see where it is at vs where it should be at per the SM. SMs can be found here. If you can do this first I'd do that in case it is buried on the Soul being a compact front end.
Indice 2
Ajouter une réponse
Cavities sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 34
Total : 104
