Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels et informations de réparation pour les batteurs KitchenAid.
My 4KSM5PSGR proline series mixer stopped working
I have a KitchenAid Pro Line 4KSM5PSGR mixer that stopped working under load.
I opened it up and found the worm gear is worn/stripped.
Where can I get a replacement?
When I ran the motor without the gears attached, it makes a bad noise. I don't know if the carbon brushes need to be replaced.
How can I tell if the brushes need to be replaced or if it is something else?
I've attached some images of the brushes.
UPDATE: Here is a picture of the commutators
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @alberteinst6187
Did you mean a KSM5PSGR mixer?
If so, the worm gear is p/n 4162897.
Check if the commutators need cleaning. Not sure re the brushes but the best I could find re their dimension is that they're 23.7 x 5.8 x 5.8 mm (when new). Their p/n is 9706416
Here's the parts list for the KSM5 model series if you need more parts.
Indice 2
15 commentaires:
@jayeff It is actually a 4KSM5PSGR can't find much about it though because it is old.
par
@alberteinst6187
I think that the "4" prefix means that the mixer is meant for overseas markets and not the USA.
The parts list attached has part numbers for the 115V,100V and the 240V models
par
@jayeff It is 120V though
par
@alberteinst6187 all the internal gears are identical between those 2 "models". BTW the brushes look good.
par
Voir 10 commentaires en plus
Ajouter une réponse
Albert Einstein sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 37
Total : 113
