L'ordinateur s'allume mais l'écran reste noir
L'ordinateur s'allume mais l'écran reste noir noir
Translation French - English
The computer turns on but the screen remains black.
Depending on the CPU (Hint: Intel), these were known to cook the northbridge because these predate the Core i series where Intel put it in the CPU and only the southbrudge is on the motherboard. A lot of these are impacted by that, but the cheaper machines like the CQ56, CQ57, CQ62, HP 2000 and even the Pavilion g6 is a known suspect :-(. I have a Pavilion G6 I got a PDC out of to put into a surviving HP 2000 someday(TM) because of the issue being an obvious board fail... BUTT I've been a little slow because these were all kind of mid for build and reliability and I had a CQ56 fail due to a bad board, so these machines... are just troublesome in my experience. HP is a lot better now especially in the last 5-7 years when RtR started taking off and they aren't problematic like the old days, but a lot of the pre RtR HP Consumer machines have some terminal defect relating to a bad motherboard, GPU issues or faulty cooling somewhere that happens to kill motherboards. HP has never had serial defects on the business lines but if you looked at an old HP Pavilion, they had some engineering defect every time.
This is what cooled the northbridges on these (seriously):
It isn't always fried motherboards, BUT A LOT OF THE TIME it is. However, what I have done to revive them before they were eWaste dead or alive but due to the weak CPUs many have, poor build and lack of W11 support made them unwanted is remove the RAM and see if I get a RAM POST error - if the error changes, the RAM is bad. But if I get the same error it's the motherboard. The SM can be found here: https://www.manualslib.com/manual/995111... -- and the HP POST codes here: https://support.hp.com/us-en/document/is... -- you want to see a RAM error, all others are bad.
Selon le processeur (Indice : Intel), ces ordinateurs étaient connus pour faire surchauffer le pont nord, car cela date d'avant la série Core i où Intel l'a intégré dans le processeur et où seul le pont sud se trouve sur la carte mère. Beaucoup de ces modèles sont touchés par ce problème, mais les machines moins chères comme les CQ56, CQ57, CQ62, HP 2000 et même le Pavilion g6 sont des suspects habituels :-(. J'ai un Pavilion G6 dont j'ai récupéré un processeur PDC pour le mettre un jour dans un HP 2000 survivant, car la panne de la carte mère est évidente... MAIS j'ai traîné un peu des pieds parce que la qualité de fabrication et la fiabilité de ces modèles étaient plutôt moyennes, et j'ai eu un CQ56 qui a lâché à cause d'une carte mère défectueuse. D'après mon expérience, ces machines sont donc tout simplement problématiques. HP s'est beaucoup amélioré aujourd'hui, en particulier ces 5 à 7 dernières années depuis que le programme RtR a pris de l'ampleur et qu'ils ne posent plus de problèmes comme par le passé, mais beaucoup de machines grand public HP d'avant cette époque ont un défaut fatal lié à une carte mère défectueuse, à des problèmes de GPU ou à un refroidissement défectueux quelque part qui finit par tuer les cartes mères. HP n'a jamais eu de défauts de série sur ses gammes professionnelles, mais si l'on regarde un vieux HP Pavilion, il y avait systématiquement un défaut de conception.
Voici ce qui refroidissait les ponts nord sur ces machines (sérieusement) :
Ce ne sont pas toujours des cartes mères grillées, MAIS TRÈS SOUVENT si. Cependant, pour leur redonner vie avant qu'ils ne finissent à la déchetterie (morts ou vifs, mais rendus indésirables par la faiblesse de leurs processeurs, leur piètre fabrication et l'absence de prise en charge de W11), ce que j'ai fait, c'est retirer la RAM pour voir si j'obtiens une erreur POST de RAM : si l'erreur change, la RAM est défectueuse. Mais si j'obtiens la même erreur, c'est la carte mère. Le manuel de service se trouve ici : https://www.manualslib.com/manual/995111... — et les codes POST HP ici : https://support.hp.com/us-en/document/is... — ce que vous voulez voir, c'est une erreur de RAM, toutes les autres sont mauvaises.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 55
