Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de la Steam Deck avec écran LCD, une console de jeux portable fabriquée par Valve, sortie le 25 février 2022. Elle porte le numéro de modèle 1010.
Having Troubles with Steam Deck Update
Ever since their was an update. my steam deck buttons, L2, Steam button and three dot button stop working if there is someone who can help please let me know
Mise à jour (08/04/26)
I also tested on the controller testing thing in the settings too test device. is there anybody out there come and help me? because i live in Perry, Ny. and got no car take me to get it fixed
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
4 commentaires
@kristoferu90180 We don't really give in-person repairs, here. And please do not give out your location, that is a doxxing hazard if you do so.
Either way, what else have you tried?
par
Okay my bad it’s my first time trying this website. I try shutting off my steam deck completely and let rest awhile because this not first time it has happened to me
par
@kristoferu90180 No worries! I think that someone had the same or at least a similar problem that you have with this particular device.
par
If there’s anything I can do make it work again please let me know. Unfortunately I don’t got any tools to take apart and see the issue is if comes worse terms might someone check it out or can wait till tell me I can do
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi!
Is the issue constantly? Or does this only happen for a short time right after a update? It sound more like firmware related to me...
Try to recover it and see if that works: https://www.reddit.com/r/SteamDeck/comme...
If that doesn't work, you might need to replace the motherboard...
Indice 1
4 commentaires:
I did the Factory Reset and still giving me issues personally I think Steam needs do another update for Steam Deck users because this not first time like I said previously…
par
Just curious do I need to Clear user data and configuration? Or just leave that alone?
par
Never mind I did full restart and sadly still giving me same issues again I’m wait till Steam updates it so be easier for Steam Deck users
par
Clear and format everything (make sure you got backups). If it's still failing even after that, you could wait for another update but this should not be normal behavior. Maybe it's for the best to contact Steam Support? Maybe they have some tip and tricks as well!
par
Ajouter une réponse
Kristofer Urquidi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 41
Total : 103
