Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations pour réparer et démonter l'Apple Watch SE de 1e génération, annoncée le 18 septembre 2020.
Apple Watch SE alive but with blank screen
My Apple Watch SE has a blank screen and the heart rate sensor doesn't light up, but I can hear the high pitched sounds of the electronics inside and I hear it responding to force restarts. How can I diagnose and fix this? Model code is A2726.
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires:
Can someone please help?
par
@amazingfixer Maybe it's a backlight problem? Try shining a flashlight at the screen.
par
@Theo Grefalda I just tested, and it is not a backlight issue
par
@amazingfixer It's got an OLED screen so there's no backlight; if the screen doesn't light up but the watch is functional I'm afraid you'll have to replace the whole screen.
par
Ajouter un commentaire
1 Réponse
Hello Amazing, There are a few steps we can try before replacing the display.
  1. On your paired iPhone, go to Settings > Accessibility > Watch Mirroring and turn it on. If the watch's OS is actually running, you'll see its screen on your phone and can control it by tapping/swiping on your phone. This alone can confirm software is fine and the problem is the display.
  2. (If confortable) The SE's screen is glued down and needs gentle heat (a heat gun or dedicated opening pad, around 80-90°C) plus a suction cup and thin pick to lift without cracking it. Once open, check the small display ribbon connector near the top of the logic board — it's common for it to shake loose or get pushed off. Reseat it firmly and test before resealing.
If #1 gives no result, then there is a bigger issue that we can troubleshoot.
If your Apple Watch does show up on your iPhone you will need to replace the display.
Here is the screen replacement guide.
Here are some options for a replacement screen.
https://www.injuredgadgets.com/premium-o...
Apple Watch (40 mm SE 2) Screen
Let me know if I can provide any further help. Happy iFixing!
Image Replace an OLED screen compatible with 40 mm SE 2 Apple Watch smartwatches model A2722, A2726, A2725, A2855.
Produit
$119.99
Indice 0
9 commentaires:
Thank you! I will see and let you know if it shows it.
par
I also forgot to mention that the heart rate sensor doesn't light up either
par
Apparently, the Apple Watch SE doesn't support Watch Mirroring, so I can't do the first test.
par
There isn't the charging noise when plugged in and there isn't any vibration
par
@amazingfixer That's my bad. I forgot it was specific to flagship models.
par
Voir 4 commentaires en plus
Ajouter une réponse
Amazing FiXeR sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 79
Total : 110
