Modèle A1278 mi-2010 / processeur core 2 Duo à 2.4 ou 2.66 GHz
Questions au sujet de 813 Voir tout
Apple hardware test Failure code...
After running a aht it gives an error : 4SNS/1/40000001: VP0R-0.000
what is the exact problem in this logic board. System is very slow . i already dismantle 3-4 times some time after assembly it works for little time means working until restart. after restart it again giving same problem.
Une réponse ! View the answer J'ai le même problème
Score 2
Commentaires:
If i Plug the Charger in then the laptop works fine no problem. while on charger also AHT gives same error . What to do??
par
I see two possibilities; use it as is, or, replace the logic board.
par
What did you do in the end ? I have exact same problem. Dont no weather to get fixed or not ?
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
If this answer was helpful please remember to return an mark it Accepted.
Cette réponse est utile ?
Score 4
Commentaires:
i already done SMC or PRAM, can you locate the specific sensor which creating this problem ? thanx in advance
par
Nope - looked but "best guess" was all I could offer.
par
it was the error of sensor on the logic board . i replaced the logic board
par
Ajoutez une réponse
SIMRAN sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 31
Total : 6,103
