Aller au contenu principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 questions Voir tout
tried to bleed and made it worst.
Hey fellow nissan folks, Having a problem with the clutch... tried to bleed and made it worst.. the padal now sticks to the floor. Anyone know the correct way to bleed the system??
Thanks so much folks.......
Don
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Donald, here is the way the manual describes it:"CLUTCH FLUID Air Bleeding Procedure
NOTE:
Do not use a vacuum assist or any other type of power bleeder on this system. Use of a vacuum assist or power bleeder will not purge all the air from the system.
 Bleed air according to the following procedure.
 Carefully monitor fluid level at reservoir tank during bleeding operation.
 When bleeding the air from the clutch fluid, first bleed the air from the operating cylinder air bleed valve and then from the bleed connector air bleed valve.
1. Top off reservoir with new recommended brake fluid.
2. Connect a transparent vinyl tube to the air bleeder valve on the clutch operating cylinder.
3. Fully depress the clutch pedal several times.
4. With clutch pedal depressed, open the bleeder valve to release air.
5. Close the bleeder valve.
6. Repeat steps 3 through 5 until clear brake fluid comes out of the air bleeder valve.
7. Perform steps 1 through 6 for bleeding air from the air bleeder valve on the bleed connector.
Hope this helps, good luck.
Indice 1
Ajouter une réponse
Donald sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,515
