MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / New
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / Without Bracket / New
  • 360°
360
$44.99
$44.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Détails du produit
Description
Description
Unable to access your hard drive?
Then you might need to replace your hard drive cable!
Please read the option descriptions. Some options do not include the hard drive bracket.
Compatibilité
Histoires de réparations
Avatar de l'utilisateur
Mon problème
This is actually a computer I sold to a friend. 1 week after the fact he called and said it wouldn't boot, there was a folder with a question mark icon. He took it to another friend who replaced the hard drive, for $100. That hard drive "failed" also. This all sounded fishy to me.
I got the comput . . .
Mon problème
After removing the hard drive and seeing that I could access the data easily and boot from it, i knew it was either the sata cable and/or the logic board. Sata cable was least invasive and least expensive so I went for that first.
Ma solution
All worked well. Computer is up and running
Mon conseil
Take your time and follo . . .
Mon problème
The previous repair cable failed within 8 months so I bought this one and we will see if the quality of it is better. So far it seems better built but will need to stand the test of time. I feel confident.
Ma solution
Easy. Very straight forward especially after having done this once before.
Mon conseil
Do your research befo . . .
Mon problème
The Apple people said I could handle it and it would be cheaper if I did it myself.
Ma solution
It went well. The computer works. Now I just have to figure out software updating then it will be like new.
Mon conseil
I replaced a cable bracket in my macbook. Screws were tiny, Other then that it went off without a hitch. T . . .
Mon problème
Hard drive would not boot while connected to the internal SATA cable but would boot correctly when placed into an external USB carrier.
Ma solution
The repair process was very easy. Remove the laptop bottom cover, unscrew and remove the hard drive hold down brackets, unplug the hard drive from the SATA cable the . . .
Mon problème
A client gave me a mid-2012 MacBook Pro for recycling after he'd replaced it. The computer rarely would boot at all. It wasn't the hard drive.
I kept the computer around, loathe to recycle something that seemed close to working.
I had bought the new part to see if it improved another client's comp . . .
Mon problème
My old SATA cable wasn't able to transfer files as fast as my new SSD's disk speeds (1/5th the speed)
Ma solution
Works great! My new SSD works find because of the new cable.
Mon conseil
Buying a new SSD? Buy this cable. (Get the one with the bracket. It helps.)
Mon problème
MacBook cable was damaged.
Ma solution
It was easy to replace and so far it works well.
Mon conseil
If your Apple warranty is expired, try to repair this yourself rather than taking your MacBook to Apple.
Mon problème
MacBook Pro worked fine with stock hard disk but refused to boot with SSD in place. Even erasing SSD was finicky and produced partitioning errors I'd never before seen.
Ma solution
Easy! In troubleshooting, I happened to have another client's same-model Mac on hand to briefly swap in their storage data cable and . . .
Mon problème
Hard drive cable - MacBook pro was running loops with bad contact to harddisk. I checked this by reinstalling Lion OS X externally on a hard drive. This worked so my assumption that the cable was faulty proved itself.
Ma solution
I tried a cheap cable from amazon but people i tell you what a waste of time and m . . .
Voir plus
