64 Bit Driver Kit
  • Refermer 360°
  • 360°
360
64 Bit Driver Kit
$24.99
$24.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Nouvelle batterie = iPhone plus rapide
Kits de réparation à partir de $16.99
Détails du produit
Caractéristiques
Caractéristiques
The ultimate high-performance bit kit
  • The complete screw-turning solution for precision repair jobs.
  • Custom handle with two-zone grip profile provides up to 8.5 N-m of torque.
    • Textured precision zone for delicate screw turning
    • Three-faceted, large-diameter grip zone for heavy duty wrenching.
  • 64 purpose-driven screwdriver bits selected based on the data from thousands of repair guides.
  • This bit kit contains bits to repair cell phones, game consoles, wearables, laptops, desktops, tablets, small appliances, and much more!
  • The specially-designed case conveniently holds and displays all the contents in high-density foam.
  • The lid of the case features an integrated sorting tray.
  • Ergonomic Aluminum Handle provides plenty of torque and grip with swivel cap and magnetized bit holder.
  • Longer bit necks for increased precision and accessibility.
Interested in purchasing more than 10? Contact Us!
Kit Includes
  • 64 Bit Driver
  • 150 mm Flex Extension
  • 4 mm Screwdriver Bits
    • Phillips - 000, 00, 0, 1, 2
    • Flathead - 1, 1.5, 2, 2.5, 3, 4 mm
    • Torx - T2, T3, T4, T5
    • Torx Security - TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25
    • Pentalobe - P2, P5, P6
    • JIS - J000, J00, J0, J1
    • Hex - 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut Driver - 2.5, 3, 3.5, 4, 5, 5.5 mm
    • Square - 1, 2
    • Gamebit - 3.8, 4.5 mm
    • Spanner - 6, 8
    • Triangle - 2, 3 mm
    • iPhone Standoff Bit
    • Oval Drive
    • SIM Eject Bit
    • Magnetic Pickup Bit
    • 1/4" to 4 mm Driver Adapter
Histoires de réparations
Avatar de l'utilisateur
Gavin Hobbs's Story Photo #1191523
Gavin Hobbs's Story Photo #1191524
Mon problème
The battery life wasn't the greatest and the battery icon had an alert that notified me that it needed checking. Additionally, the touchpad's click wasn't working... only the tap.
Ma solution
The repair went perfectly! I found a whole bunch of dust and stuff and cleaned it out with the vacuum hose.
Mon conseil
Take it slowly . . .
Alex Anfrie's Story Photo #1268915
Mon problème
My phone fell off my car and ended up with a broken screen
Ma solution
The repair went well, i struggled a bit trying to figure out all the parts (cameras, speaker, etc) that needed to be taken off the old screen to the new one
Mon conseil
Don't forget the parts on the old screen that needs to be placed on the new one:
Jack . . .
Mon problème
The factory battery began to expand and was causing problems.
Ma solution
Very easy and simple. Just needed the right screw driver bit.
Mon conseil
Nope.
Mon problème
My Gamecube C-Stick was drifting in games.
Ma solution
Will be quick
Mon conseil
With the proper driver I could unscrew the triangle screws holding together controller. I noticed that a new C-stick is needed. Now all I need to do is replace the C-stick with a similar stock item.
Mon problème
This is what we do..
Ma solution
as it should
Mon conseil
Never give up.
Mon problème
After we moved into our new house, our PS3 would overheat within seconds of powering it on.
Ma solution
After following the steps for the full teardown, I was able to see that the thermal paste needed to be replaced in two spots. After carefully removing the old paste and replacing, it powered on and worked like . . .
Mon problème
I had to remove a large heatsink from my CPU to replace the CPU, hwoever Hyper 212 evos arte notorious for being less than steller with their X bracket mount despite otherwise being an awsome cooler. So I purchased the 64 peice driver set and it worked amazingly. Arrived a day later than expected bu . . .
Mon problème
I broke my iphone 5s screen and decided to buy the 64 bit repair kit, a suction cup, and bought a cheap replacement screen from another source.
Ma solution
In the beginning it actually went quite well. I removed the screen, removed the screws, the covers, and removed the screen wires. the transferring of compone . . .
Mon problème
My mouse was clicking by itself and going nuts.
Ma solution
Very detailed and simple. Fluid, smooth guide and the tools came so quick! and handy! THOROUGHLY IMPRESSED!
Mon conseil
Be patient, and be gentle. ANYONE CAN DO IT!
Mon problème
My CPAP machine broke down and a new unit just wasn’t in my budget. But you know what was? The 64bit kit.
Ma solution
After watch a video from YouTube, I saw that the tools needed were in a kit offered from iFixIt. And in the past I’ve bought kits for the iPhone 4s and iPhone 6 and I knew that they provided . . .
Voir plus
