Magnetic Project Mat
$19.99
$19.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Nouvelle batterie = iPhone plus rapide
Kits de réparation à partir de $16.99
Détails du produit
Caractéristiques
Caractéristiques
Repair can be tough. This mat makes it easier.
  • Simply organizes all your parts while you work on a device.
  • Dry erase surface lets you keep notes and stops mistakes.
  • Reduces reassembly time by up to 40% while preventing errors.
Designed by fixers, for fixers, the 8”x10” Magnetic Project Mat solves this repair problem. Spacious and secure, the mat will catch and hold screws as you pull them out of a device.
Great for cell phone repairs, and you can stop worrying about screw tracking and focus on the cell phone all the screws will be right where you left them. For laptops with hundreds of screws, use the whole mat as a screw guide and keep careful notes to not get lost.
The included pen is uniquely suited for the Project Mat. It’s made by Staedtler, the German pen company that makes top-of-the-line pens and pencils for artists and architects. Their Lumocolor Correctable pen doesn’t smear or wipe away like most dry erase markers, so if you brush your hand across the mat while performing a repair, the ink doesn’t scratch or smear. However, the eraser tip or a dry cloth wipes the ink away clean.
Pen wearing out? We have replacement pens.
Vidéo du produit
Histoires de réparations
Avatar de l'utilisateur
Jacob Bramante's Story Photo #1291959
Mon problème
My battery life was short and the laptop would shut down at 50% or higher if I had a portable drive connected.
Ma solution
Thought about trying to cheat the repair by not removing the logic board et al, but then just settled in for the long slog as I've been working on computers for years (built my first one in . . .
Mon problème
got it to be prepared for a problem.
Ma solution
have the tools to do the work.
Mon conseil
None yet.
Mon problème
Battery was not holding a charge for any longer than a day.
Ma solution
Great instructions, good pictures, bad experience. It all began like the instructions indicated by removing the two external screws, placing suction cup on screen and attempting to separate the screen from the body. After numerous attempts . . .
Mon problème
My battery was ruining my phone. It destroyed 2 cables and was rendering my phone useless.
Ma solution
It was straightforward and fairly easy. If you can shade tree mechanic then you can fix a phone no problem.
Mon conseil
Pay special attention to the screw lengths and where they come from and go back to. There are notes f . . .
Mon problème
The price of adding more SSD storage and memory via Apple Store is extremely costly.
Ma solution
It is definitely a moderate to difficult task in performing this upgrade but it was well worth it! Interested parties should also read advise about how to deal with slow boot-ups if they also upgrade the SSD at the s . . .
Mon problème
Noticed more cellular data use and gps data unreliable on my daughters phone
Ma solution
Just follow the directions, it was easy
Mon conseil
If you have a low wifi signal and the gps location is not very accurate, this is the fix
Mon problème
Son proyect
Ma solution
Son proyect
Mon conseil
Son proyect
Mon problème
My daughter's phone battery would go from 50-60% to shutdown in minutes, especially outdoors in cold weather.
Ma solution
In addition to the repair kit, I bought an iSclack, an iOpener, and the magnetic project mat. The iSclack is worth its weight in gold. The magnetic project mat is worth ten times that. I d . . .
Mon problème
The battery would only hold a charge for a few hours. I thought, “Rats! I don’t like replacing a phone when it was otherwise perfectly meeting my needs.” Then I heard about Ifixit and the possibility of fixing it myself.
Ma solution
The guides were so detailed it made the process easy. Equally important w . . .
Mon problème
I was hitting thermal limits on my graphics card during this excessive heat wave in california. Decided to do a budget friendly mod on it. Replaced the stock gpu fans with case fans. Problem was i couldnt remove the stock fans because i didnt have the tips needed for it.
Ma solution
Great! I was able to remove t . . .
Voir plus
