Metal Spudger
  • Metal Spudger
Metal Spudger
$2.99
$2.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Détails du produit
Description
Description
For when you need that unyielding edge.
  • While our first-choice tool for poking and prying is always our trusty plastic spudger, sometimes you need a little more power behind your pry. In those instances, this metal spudger is the ideal tool for the job.
  • Features a comfortable, easy-grip handle and is great for prying up all sorts of tough components.
  • For the metal spudger fanatic, we also sell a set with an entire assortment of four different metal spudgers, for all of your hardcore spudgering needs.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Vidéo du produit
Histoires de réparations
Avatar de l'utilisateur
Gordon Krupsky's Story Photo #863027
Mon problème
About a year ago, my left channel went almost dead. It was there, but so faint that you couldn't really hear it. I don't listen to my iPod through headphones too much, but I do use an FM transmitter in my car that gets audio via the headphone jack. In the car, instead of just having a dead left chan . . .
Mon problème
Battery would not charge.
Ma solution
Difficult to open the case, but was able to do it with patience, and without damaging the case.
Mon conseil
Study the pictures in steps 21 and 23 to understand what the clips look like and the locations so that you know where and how to probe with the metal spudger to release the clips.
Mon problème
Battery
Ma solution
Awesome
Mon conseil
Do not use them rip off kiosks at the mall. Do it yourself! It's very easy and way cheaper.
Mon problème
Crack screen on a Verizon Surface 3, unusable in it's current state.
Ma solution
Getting the old screen off was a pain. Lots of little pieces. Wish i would have known to just get one corner done and get to the meat of the screen. From there i could have possibly pulled it off faster with less shards!
Mon conseil
Rated as a 1 . . .
Mon problème
Won't boot up
Ma solution
Order arrived in reasonable time & good condition. Prybars popped the case of Nexus 7 quickly & undamaged as advertised. Didn't find the quick & easy loose battery connection hoped for but tools were great. Will continue & possibly use other tools as time allows.
Mon conseil
Best advice may be buy . . .
Mon problème
Recently, I needed to replace the battery on my 6-year old Dell Adamo 13. I referred to the clearly written Dell Adamo 13 Teardown and clicked on the "Buy these tools" button to order all the recommended tools.
After receiving the tools, I realized that I still had no way to open the computer case . . .
Mon problème
Front panel cassé!!
Ma solution
Bien été mais il faut faire attention de pas trop chauffer avec le heat gun!! Regarder aussi le vidéo en plus des étapes!
Mon conseil
Suivre les étapes et prendre sont temps!!
Mon problème
broken display
Ma solution
I bought the wrong display and I had no problem with the return. I got the right part and I followed the steps and had no problems. Thanks!
Mon conseil
Follow the steps very easy!
Mon problème
iPad was discharging quickly. Then it would not charge at all. Would not turn on or charge (dead). Determined the battery needed replaced.
Ma solution
Used the iFixit guide and was able to successfully repair. I used a hair dryer to soften the adhesive and was very patient (heat, cautiously pry, heat and pry, . . .
Mon problème
Accidentally our iPod classic fell unto the floor and consequently the harddisc was broken. The best solution seemed to be a replacement of the drive with a CF-card. If there is any pride, you go for it on your own and fix it.
Ma solution
To start the opening process I found it easier to use a kitchen knife ins . . .
Voir plus
