P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA / New
$8.99
$8.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Détails du produit
Description
Description
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
The iFixit P5 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P5 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Histoires de réparations
Avatar de l'utilisateur
Mon problème
battery was dying and had "service battery" alert in notifications panel
Ma solution
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
Mon problème
Needed more RAM memory to upgrade to High Sierra OS.
Ma solution
Great.
Mon conseil
Make sure you hav the correct RAM memory because there are various types.
Mon problème
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
Ma solution
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
Mon problème
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
Ma solution
Everything went without a hitch. Thank you!
Mon conseil
Follow directions. Carefully unplug and reconnect battery.
Mon problème
After five years the battery had cycled hundreds of times and was showing a need for service...
Ma solution
The swap was quick and easy... less than 20 minutes... great repair guide and product.
Mon conseil
ifixit.com should always be the first place you try.... great advice and solid products...
Mon problème
Original Logic Board had failed
Ma solution
Repair went without a hitch.
Mon conseil
Follow the instructions!
Mon problème
Trackpad kept drawing squares
Ma solution
Good.
Mon conseil
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
Mon problème
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
Ma solution
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
Mon problème
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
Ma solution
My biggest problem was that I didn't even know whic . . .
Mon problème
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
Voir plus
