Precision Tweezer Set
$9.95
$9.95
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Détails du produit
Caractéristiques
Caractéristiques
Grab everything from screws to eyebrows.
  • Perfect for all holding, pulling, squeezing, picking up, and plucking jobs.
  • Different tips for different ships: pointed for ultimate precision, angled for ergonomic accuracy, and blunt for heavy lifting.
  • Protective coating prevents ESD damage from harming sensitive electronics.
These are also available as individual Tweezers. Having a hard time seeing what you're tweezing? Take a look at our Magnifying Tweezers.
Histoires de réparations
Avatar de l'utilisateur
Riley Baker's Story Photo #662372
Riley Baker's Story Photo #662373
Riley Baker's Story Photo #662374
Mon problème
Authorized Surface Technician for several brands of Laptop/Tablet/Phones
Our current tools where rubbish, some of them 15 years old.
Ma solution
Great, the tools where ordered Friday evening, and arrived by lunch time Monday....In New Zealand, great job iFixt on getting the order ready and shipped so quick.
So . . .
Mon problème
I was fixing it for a student that wanted his/her IPad fix.
Ma solution
The repair went ok, it took around Three hours to repair. I really have to take time to heat the glass to remove. So I don't break the glass, if you do break the grass. you just might scratch the surface of the LCD screen.
Mon conseil
you will need the d . . .
Mon problème
I repair my own and friends' and clients' computers, I needed to stock up on tools and supplies.
Ma solution
To quote Al Green's song: 'How can you mend a broken heart?" These tools didn't do it...
Mon conseil
Yea. Don't ask a wiseacre like me for advice, I'll tell you to wear clean underwear in case you get in an accident . . .
Mon problème
These purchases were just additional pieces to my toolbox, but I do love the heavy-duty spudger, it's very durable.
Ma solution
Overall it went great, but I couldn't finish the 3G until the suction cup came in, so this is just part #1 of the repair
Mon conseil
Nothing, great guides and tools. I've made consecutive purchases . . .
Mon problème
I had a bicycle accident and I got my iphone 5S crystal scrren and lcd broken
Ma solution
Just fine. I had a little problem during the front button reassembly refering to the metal support and a small squared linner but finally i got it the right way.
Mon conseil
the step-by-step guide was of great help and the video guide t . . .
Mon problème
Shattered screen. And a weak battery that I bought a replacement for at an iPhone repair store.
Ma solution
First of all be aware that the Display Panel Assembly is not the same thing as the Front Panel Assembly. You save money doing the Display panel assembly kit but it's a bit more treacherous. Otherwise, besi . . .
Mon problème
My girlfriend has anger issues and decided to take it out on her iPhone 5c. On the right corner of the glass it was completely missing and glass in front of the camera was gone as well, leaving the camera completely exposed. She upgraded to the 6 and I have been working on phones for a couple of mon . . .
Mon problème
LED screen was crushed by my wife!!!!
Ma solution
The recommended replacement part suggested by Fixit was perfect and the repair went as discussed on the How to pages. Only problem was the suggested Phillips screw driver did not fit the tiny screws and had to be modified to fit. Otherwise, a piece of cake.
Mon conseil
Use . . .
Mon problème
My lens had a hole in it so i ordered a new one and some tweezers off here along with a cleaning brush for my battery cover part because it got alot of gunk in it. My battery cover broke off a while ago. So i got one off ebay for .99 cents
Ma solution
It was easy and took about 10 minutes
Mon conseil
Make sure all the glass . . .
Mon problème
I had an Apple Service center replace the top half of my MacBook pro 15" due to a crack in the screen. Ever since then I've had horrendous wifi reception. When I talked to them they said I'd need to drop it off for 3-5 days for "diagnosis". I was 99% sure they hadn't reconnected the Wifi antenna cor . . .
Voir plus
