Tri-point Y1 Screwdriver
  • Tri-point Y1 Screwdriver / Moody - Made in USA / Fixed Blade
Top of the line professional made in USA driver with swivel top ESD safe ergonomic handle.
Lifetime Warranty.
$12.99
$12.99
Nous vous enverrons un message lorsque le produit sera à nouveau disponible.
Détails du produit
Description
Description
The tool you need to overcome security tri-wing screws.
  • Frequently used to deny users access to device internals, getting past is simple with the right tool.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fits fasteners found on some Apple laptop batteries that use Apple Tool 922-8991.
  • Fixed-handle drivers make a great complement to a Mako Driver Kit - 64 Bit Driver Kit.
  • Upgrade to pro for an ESD safe professional-grade driver.
Histoires de réparations
Avatar de l'utilisateur
John's Story Photo #1174489
Mon problème
My brother spilled coffee on his wife's 13" MacBook Pro...two years ago! They've just let it sit because they thought it would be too expensive to repair.
Ma solution
SUPER easy. The guide was thorough and easy to follow. The only hitch was that after I replaced the logic board, I realized that 1. The battery wa . . .
ferrellmc's Story Photo #1438039
Mon problème
The battery expanded and pushed up the touch pad like it was a bulging disc in my laptop. It not only looked broken but it also looked painful. My 7-year-old granddaughter said, "Oh my, I'm not sure it will ever work again."
Ma solution
The old battery had expanded like a pregnant woman's foot in her shoe. The b . . .
Mon problème
Needed the tri wing screwdriver for older MacBooks and macbook pros
Ma solution
Went well, added the screwdriver to my wiha collection will be using everyday
Mon conseil
no advice
Mon problème
The battery of my 2012 MacBook Air was getting long in the tooth, and wasn't going to last much longer. As my primary travel laptop, I need something I can rely on.
Ma solution
The repair went well, with the help of the special iFixit tools, and online instructions detailing what I needed to do, when. The only . . .
Mon problème
Needed a good tool to remove the battery screws.
The tools that shipped with my amazon battery replacement were not good. They started to strip the screws. After several tries I stopped. However, I remembered that I ordered a memory upgrade kit with a great Mac tool from iFixit several years ago. T . . .
Mon problème
My old GameCube controllers had never been cleaned in the 14 or so years I've owned them. Decided to finally do something about it after seeing a video.
Ma solution
It went surprisingly well, heh. I was afraid of frying the circuit boards both times.
Mon conseil
Definitely come to this site for specifics on how to fix whatev . . .
Mon problème
The MacBook Pro battery over heated and expanded within the laptop. It caused multiple restarts and other issues.
Ma solution
The repair was easy with the assistants of the online tutorials. The end result was a working laptop.
Mon conseil
Trust yourself and rely on help from the pros at iFixit
Mon problème
Dead battery, it won't charge.
Ma solution
It went pretty smoothly
Mon conseil
Be careful disconnecting the battery
Mon problème
One drop of water from condensation from a glass of lemonade, and no one makes a silicone guard for this?
Ma solution
Wow, that was even easier than it looked. The instructions here were clear and correct. They made the job a snap. Every repair/upgrade I've ever tried was right here. I love this site. %#*@ Apple . . .
Mon problème
Original battery would not last 45 minutes of usage.
Ma solution
Fairly easy
Mon conseil
Make sure you are careful with the tiny screws. They are very small.
Voir plus
