Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
« Retour à Toutes les histoires
Friend required easy access to his iPhone
zakk -
iPhone 5
iPhone 5 Pentalobe Screws Replacement
1 minute
Easy
Mon problème
My friend needed easier access to his iPhone and didn't want to always need to go looking for a Pentalobe screwdriver, (which he doesn't own) each time.
Ma solution
The change of screws is very easy, just unscrew the Pentalobe ones, and screw in the new Phillips ones.
Mon conseil
If you have the 54 bit driver kit, it can make it a little easier, but the provided screwdrivers work well and are actually good for small field jobs or if you can't be bothered carrying a full bit set around for a quick fix and are definitely worth keeping.
Ajouter un commentaire
